Jza
I know the answer is to go back to mapper (150 mile round trip) but im not sure its to do with the remap...... hence question.
2011 Gen 2 - ECU remap full Yoshi system. It has always been a bit "on off" at low revs on a constant throttle but has got worse and worse.. after initial ECU remap it seemed to have solved it...
My bike now starts ok but after the intial firing into action (about 10 secs) the revs drop and it stalls. Starting it again i need to hold the throttle open a bit till it warms... other wise it stalls. ive set the tickover a bit higher but its not that... its also started to backfire!
Wondered if anyone has any ideas.. as i say im not convinced this is the re-map as it was fine and now suddenly got worse...
Jza
Jza
