i have the Zfi+Qs, and its all installed, the ecu is getting the signal from the quick shift linkage, but when i try to shift with it nothing happens. no engine kill or anything. one thing i noticed while seeing if it was getting signal to the ecu was the sensor took more effort to actuate than the gearbox did to move. basically i could make a shift then at the end of the throw i would have to push a little more to move the plunger then the bazzaz unit would light up. is this normal? do i need to adjust the shifter down a bit to get more leverage on it? any help is appreciated.
