Draco1340
Last night was the first time I had the opportunity to try out autoshifting. I have a PCIII with USB hub and a Cycle-Tek air shifter. I had the PCIII set to shift at 12k. I bench tested the system on a stand at 5k rpm to make sure it was working before going to the track.
The track was a skating rink last night. Cold temperatures (~45) and zero track prep... The autoshifter didn't seem to work at all, and I am wondering if a) the system doesn't work if there is any tire spin, or b) if there is some setting in the power commander that controls the duration of the output to the shifter.
Any thoughts? I gave up and disconnected the autoshifter after verifying my factory rev limiter was working just great
