air shifter bottle
GNBRETT
it will mount fine with a 1 lb bottle or a smaller bottle. u just need to drill two holes and get two clamps to hold it. it will be close to the rear tire but will clear just fine. kinda a PITA to take out but no big deal.
Ludicrous Speed
On my Gen1, I mounted the MPS bottle under the tail section on the RH side, by the passenger peg. On my Gen 2 I had a 9 oz Co2 bottle that I took the valve apart and drilled and tapped for 1/8" npt where the pin valve was and also on the burst valve hole. I then mounted it in the same place. THe Gen 2 did not have as much room
