2008 and up shift light set up
071300r
LEFT BUTTON - SELECT ***** RIGHT BUTTON - ADJUST
1. Press and hold the left (SELECT) button.
2. Turn the ignition on, continue to hold the select button down until the instrument panel boots up .
3. Release the select button.
4. Press the right (ADJUST) button one time.
5. A symbol that resembles a lightning bolt will appear.
6. Pressing the right button again will toggle through the shift light settings--- on, flash or off.
7. Press the left (SELECT) button again... one time.
8. Little dots/squares appear - this is the brightness setting for lamp.
9. Press the right button to add more dots - more dots brighter lamp.
10. Press the left (SELECT) button again- tach needle will move to default setting.
11. Press the right (ADJUST) button to move the tach needle to the desired setting.
( 500rpm at a time below 8000 rpm, 250 above 8000 rpm)
12. Press the left (select) button to exit out.
Might wanna add that the bike has to be in neutral (if you don't hear the fuel pump run once the key goes on this will not work). :thumbsup:
