2 wheel drive?
Busa1166
Not sure if it's a repost ran a search came up empty if it is sorry. It's a very interesting system i don't do twisties but i wonder if this would help those that do.:laugh:
seems to be an old vid but as I said search came up dry for me.
WOW the more I research the more I am surprised the Suzuki Nuda was the first 2 wheel drive bike back in 87( I should have known Suzuki would be first). Unlike the shaft drives of the Nuda this one seems to use hydraulic pressure transference from the rear wheel. :dunno:
djsin
Lily's Daddy
looks like it uses a cable to turn the wheel, I'm betting it isnt strong enough of a setup to work while on the ground
Busa1166
found it on youtube was reading the comments designer says it works on hydraulic pressure fed to the front wheels through lines to the front axle an even then power isn't supplied by the pressure until the rear wheel looses traction.??? you know how it is until it starts winning races it's just hype:laugh: But supposedly it has been used in races MX
Latest Bikes
Forum statistics
Threads
173,387
Members
47,939
Latest member
Hayabusa4448
