I changed my oil a week ago, I posted this hint.
Remove the 2 plastic fasteners at the bottom rear faring, just in front of the rear tire.
Remove the RH side faring bolts.
Remove the 3 fasteners, 1 plastic, 2 bolts from the upper faring, right under the throttle grip.
Remove the 2 plastic slide fasteners from the bottom of the front faring, below the oil cooler. HINT, Note the way the faring fits together, it only goes back one way, like a puzzle, also the little nodules have to be pushed up to release the faring to let it expand.
Remove the plastic slide fastener at the upper RH corner of the radiator.
Tape the end of a wide flat blade screwdriver.
Pop the faring nodule out of the rubber grommet just above oil fill cap using the taped screwdriver.
Raise and prop the tank.
Pop the upper faring nodule out of the rubber grommet located under the RH side of the tank using the taped screwdriver
OK all of that was probably an insult to you mechanics, but here is the real hint.
You can STOP right there, the lower faring can now be pulled out far enough at the bottom to remove/replace the filter. It's still tight but not too bad, and much better than continuing to remove the RH faring completely.
Then put it all back together.
BTW, I've already designed a remote filter, I'm going to the machine shop today to fab it up.
