cobravenom39
Hey does anyone have a really good write up?
The stickied link isn't working.
Thanks.
Thanks.
just a thin smear of ultra black will do the trick..Doe anyone know the exact size of the 0-rings (id and od) in the brocks kit?? I can get them from my work, but I need to the know the size. If you figure it out, I'll send you a set to do your own!!!!
I'm pretty sure the plates have a milled slot for the o rings to sit into. Are you going to be able to do this on a machine?
