When troubleshooting you have to absolutely rule out all the easy **** first.
The fact that batts crancking engine and then holding 14.5 volts when runing is telling me that batt's good.
That leaves plugs. and yes, they are resistor plugs and I have seen them open up and not allow a spark to pass yet look like new. Sometimes they even go intermitent and work at lower rpm's and quit at higher rpms. I have seen plugs fail sooner than normal too. Usually you can get 15k easy on a set of plugs.
I don't think that the battery caused my problem. What baffles me is WHAT is the debris on the injectors and IN THE mounting holes and how did it get there
lease:
I think these are my choices
1. Replace the injectors ($175 each x 4 = $700)
2. Have the injectors professionally cleaned. (cost unknown)
3. Re-install everything and put injector cleaner in the gas tank.
4. I Will replace the spark plugs. Standard CR9E (about $16)
5. Something else???
I would like to take a mini poll (say 10-15) members as to what they would do if it was their bike. Keeping in mind that I can't break the bank. I know I will have to spend some money as I don't think it will fix itself for FREE.
If whatever I do next doesn't fix it, I'm afraid I'll have to take it to a dealer and have them put it on a scope or something. I'm also afraid that they will tell me I need a new ECU at $1500 or so.
Post your opinion and I'll take the top 2 responses and apply them first
Don't forget to comment on how/why the debris got on the injectors etc., if you Know or have see this before. Maybe nobody knows or has seen this?
As usual THANK YOU in advance for your help. Past and Future
