samw5
Just finished installing my Yoshi TRS duplex system. I've done a small box mod, removed the pair valve, and I have a TRE.
I spoke with JC, he recommended the Yoshi Duplex map from the Dynojet site (M312-012). I've loaded it to my PC but idle seems to be a bit rough on the edges.
Not sure if that's cause I have more air going in (small box modded) or because of the TRE (tried to take it off but still not much changes).
I was wondering if the HMF High Mount with small box map (M312-019) would work any better. I'm afraid and trying it and screwing things up. Down low the HMF seem to add a little bit extra full. Mid range looks close and again a tad more full on WOT higher up.
Does the TRE influence what the map should look like?
Also on a side note, I was just checking the Yoshi install instruction PDF and noticed step 18) that says "Rote rear axel so that the nut is on the left side"... Which nut are they taking about? The 32mm axle nut (why would it need to be "rotated"??)? Bit confused about this step but since it has a big caution sign next to it I figured I would ask.
Any help regarding this would be greatly appreciated!
