I bought a set of used yosh cams a little while back, once installed, the bike seemed to ride fine, never beat on it, just neighberhood driving. Then went to get the bike tuned using the tuning link on the dyno. At around 60-70% at about 7k rpm, it started breaking up real bad and cam position sensor code popped up. checked everything, even pulled the cams out and miced them to make sure there was nothing wrong with the cams, measured the cam pin compared to a atock one and everything looked perfect. i installed the stock set and bike was perfect, then went and installed the two intakes and still everything was perfect. i contacted yosh and they could think of what was wrong, took over two months of dealing with them and finally just sent them back to them, they checked them out and called me to tell me the cams were fine, then they proceeded to tell me that even though suzuki says to set the cams at 15 pins on the chain from one sprocket to the other, they set their cams at 14 pins. i never had the 2ND page of instructions and they never mentioned this to me over the phone the numerous times i poke with thier sportbike tech. at least now i know what the problem was, and the cams are on their way back to me now so i can finish putting the motor back together, i had them e mail a complete set of instructions with the proper settings THEY use, if anybody buys used yosh cams and did not recieve the 2 pages of instructions, im me and i will send you them, my cams came with 2 copies of the first page.
