R Rexarmy Registered May 30, 2005 #1 This may be a stupid question but. What octane gas do you use? 87 89 93 <!--EDIT|Rexarmy Reason for Edit: None given...|1117466772 -->
sccrvettel82 I've been quiet lately...Don't m Donating Member May 30, 2005 #3 87-89...mostly 89. There is no need to run anything higher unless you are running high compression or suffering from detonation problems.
I Ideal Automotive Registered May 30, 2005 #8 i run 93 octane from sinclair,,im sure it's a little over kill,,but detonation is like taking a hatchet to your pistons
S shenoyp Hayabusa Master Jedi Donating Member May 30, 2005 #12 I use 91 for Elenor!! Not needeed... but call me escentric
G greeneinc Donating Member May 30, 2005 #19 I used to use Sunoco 94 octane with some Cam2. Then again it was in my GSXR750 with the heads done and a piston kit.
busa_boy_69 Registered May 30, 2005 #20 (greeneinc @ May 30 2005 said: I used to use Sunoco 94 octane with some Cam2. Then again it was in my GSXR750 with the heads done and a piston kit. Click to expand... +1 for sunoco 94 octane here.
