Bill,
You are softer than a block of butter left in the sun, but I love your drive.
Regarding fuel, we mostly run Sunoco race fuels up hear in NewEngland. For a nitrous motor running the mile, you want to run a leaded, non oxygenated fuel designed for very high rpm and very high compression ratio. Also, zero ethanol. There are a lot of fuels designed for car motors, but car motors don't typically run at 11,400 rpm for 30 seconds. The fuel also needs to be compatible with compression ratio's of over 15:1. Your motor doesn't have that high a CR, but on nitrous, it effectively does.
The best Sunoco fuel for that application is Sunoco Maximal.
Maximal - Traditional Race Fuels
Its 116 Octane, and designed to burn very fast, in motors running over 10k rpms. This is what many of the pro-mod, and funny bike riders use at our track. Its also very stable, and can be left in the tank for weeks without F-ing up your injectors and such.
I have less experience in VP fuels, and quite honestly had horrible experiences with MR9 and MR11 for non-nitrous motors. That being said, an equivalent fuel to Sunoco Maximal would be VP C16 or VP NO2. I have no experience with the NO2, but the specs look good.
These fuels are overkill for a 30 shot, but they are the safest fuel to run for long durations.
Bill, regarding your setup, a couple of suggestions. See if you can get a dual line system that plumbs into the dual airbox inlets on both sides. Running 2 20 HP jets in front of the air cleaner will give a more homogeneous mixture. Remove the air filter, or cut the paper element out leaving the screen. Moisture can freeze on the filter and plug it up during spray. Consider getting a pressure regulator to keep the flow constant. Pressure drops a lot over 15 seconds. You might find yourself running stinking rich at the top end as the bottle drops in pressure. As the gas flows out of the bottle, it chills the bottle and drops the pressure quickly.
If you end up running the setup at Loring, give me a shout and I'll tune for you. Good luck.
Tom.
