I was told that is a bad idea... I honestly don't know for sure, but I was told remove it or gut it (the stocker).You can just leave the in tank pump where it is and put on the external and run it off that.
That is a good price. Figure that that pump is the smae pump used in 550hp Mustangs and more.Here is the pump. http://store.summitracing.com/partdetail.asp?part=23235
NE, I know you have told me a few times, but doesn't T-rex also make that fuel rail you run? Also, what was the deal with the flow being better in the new fuel rail?That is a good price. Figure that that pump is the smae pump used in 550hp Mustangs and more.Here is the pump. http://store.summitracing.com/partdetail.asp?part=23235
I had a fuel rail made for me out of solid alum. The flow on the design was almost double. Less resistance against the flow, just very straight.NE, I know you have told me a few times, but doesn't T-rex also make that fuel rail you run? Also, what was the deal with the flow being better in the new fuel rail?That is a good price. Figure that that pump is the smae pump used in 550hp Mustangs and more.Here is the pump. http://store.summitracing.com/partdetail.asp?part=23235
Thanks
