Primary Drive Ratio 1.596 (KPH) (KPH) (KPH)
1st Gear Ratio 2.615 9.275 0 135 135
2nd Gear Ratio 1.937 6.870 34 182 182
3rd Gear Ratio 1.526 5.412 43 231 231
4th Gear Ratio 1.285 4.557 51 274 274
5th Gear Ratio 1.136 4.029 57 310 310
6th Gear Ratio 1.043 3.699 63 338 338
Front Sprocket (Teeth) 18 2.222
Rear Sprocket (Teeth) 40
Wheel Rim Size (Inches) 17
Tire Width (MM) 190 Gear (MPH) (MPH) (MPH)
Tire Depth (%) 48 1st Gear 0 84 84
Engine Minimum RPM 2,000 2nd Gear 21 114 114
Engine Maximum RPM 10,800 3rd Gear 27 144 144
Change Down RPM 4,000 4th Gear 32 171 171
Change Up RPM 8,000 5th Gear 36 194 194
Maximum Power RPM 10,800 6th Gear 39 211 211
ratios are all fine 10800 Max rpm 48% wear which would be about 76.75 circ handy chart. Should have percentage of tire whear and total circ. then it would be very accurate. You should be able to put in wind resistance to I would think with the right formulas.
