shogun
hey guys, ok so a few weeks ago my sprocket cover was off, pressed the clutch lever, liquid pured everywhere, piston came out, and yesterday i was in the process of bleeding the clutch.Im bleeding it for what seems and eternity by now and i finally start to feel resistance in the lever. I notice i can hear a slight 'squishy' sound coming from the piston everytime the clutch lever gets to the bottom of its travel. so i think its nothing and keep on bleeding, but the more i bleed the more air bubbles i see coming through my transparent line. is is possible that the piston seal is bad and that squishy sound is the piston sucking in air as i press/release the clutch? this would only make sense to me because the more u bleed the line you should have less and less air bubbles, but in my case they dont seem to go away and now im thinking that squishy sound when i press in the clutch all the way and release is air being pulled into the system. any help or thoughts is appreciated guys, as usual
