Water Pump
GSXRFANN
FLUNKIE
Does anyone know if htere is a 12vlt water pump available for a 2003 Busa. You know, kinda like they use on a drag car? It would be nice to have one, as the fan just cools the water in the radiator. An electric pump would cool the whole motor while in hte pits. I know the bike would have to be connected to a charger all the time, but the temp differences would be well worth it.
How will it cool it? the cool water once thru a hot motor will still be hot water? the thermostat will shut at a certain point and no water will flow anywhere?
Couldn't you remove the thermostat and put in a small restrictor plate to have constant flow?
Posted via Mobile Device
RCC has a few differnt electric pumps available. I've used the electric pump and the rad fans to cool things down with the engine off. IT works very well to prevent heat soak.
