Long story short I put a Gen1 in a 4x4 buggy. I used a radiator and fan off of a truck and it works great.... most of the time. The problem im having is because I mounted the radiator in the back of the buggy and when I go up steep hills the radiator is below the motor and wont gravity feed water to the motor. Motor gets hot and I back off the hill and it immediately cools back off within seconds. Im thinking the fix to my problem is using an electric water pump mounted at the radiator so it will always have water feeding the pump to push to the motor ( about 5 feet of hose ). Ive tried searching on the forum but couldn't really find anything.
Im assuming I have to take the mechanical pump off and put a block off plate on and gut the thermostat so it wont close off and cause a hose to blow off from the pressure of the pump?? Also, can I block off the barb that comes out of the side of the thermostat? Im not really sure what it does and it made me plumb the overflow with a T because the truck radiator doesn't have an extra barb like the busa radiator does.
Any recommendation's on a pump and info or a link on how to plumb it up would be greatly appreciated. I doubt any pump that mounts to the motor will now work for my pain in the butt application.
Thanks in advance
Thanks in advance
