My bike is a 2008 busaThis is definitely a new one for me.....
Sounds like something is crossed up in the wiring....
Please provide a little more details on your bike.
Generation of bike
How old is the battery
Where was the bike stored? could a furry beastie got in there and gnawed a few wires?
Has there been any mods to the lighting
Do the signal lights flash or are they on
Is the tail light on
Does the dash light up?The signal light flash juste a little bit, like on/ON.
the high beam never come on
You can get plugs and change out that particular pin.....what I'd be more worried about is why that blew like that, there must have been a surge in the system somewhere...I think a find the problem, now this piece can be change ?View attachment 1636145View attachment 1636146
Yes, looks like that burnt terminal in that block is a ground wire . . most likely a loose connection at the terminal causing high resistance in the circuit, specifically at that terminal . . high resistance = heat and what you see there is the result of heat.This plug is only for the light and the black one is the main 0 volt. So i hope its only a lose connection between the wire/plug/pin.
