Michael Lucas
I have a 2000 Hayabusa rolling Chassis and controls/switches, I have a 2003 motor and ecu, and an 07 Wiring harness. The motor is getting fire b/c we sprayed starting fluid in the carbs and it fired up. but we cannot hear the fuel pump kick on, and the FI light is not lighting at all, and the gauges dont move when you turn on the switch. also the right turn signals stay lit both front and back when key is on, and NO headlight. if I hit the left turn signal the Head light flashes with the left turn signal. I am wondering if i get newer controls if that will fix my lighting issues? and What to do about not getting the fuel pump to kick on? SOMEONE please help. I am running the 03 fuel tank and pump.....
