Jbmototech
Ok so had a chain break and it wiped out all kinds of crap snapped output shaft sprocket cover water pump etc replaced output shaft with a Robinson shaft get the motor back together and now there is a clicking sound coming from what sounds like clutch side tore it all apart everything is good put it back in same noise so i pulled motor back out split cases again took the trans completly apart and put it back together no signs of anythung wrong could the shift forks be bent just enough for the dogs to be just kissing each other the only thing i noticed was the pins ont the forks seemed to have a bit of wear ideas .......
