evoboarder
Hey guys, I know there are many threads out there on this problem but I just want to see if you have any other tips or ideas.
My bike is an 08 bus with around 17000 miles on. The only thing that isn't stock are the Yoshi pipes.
So here is what I have noticed wrong:
-While the engine is off and in neutral, it rolls just like it should. When in first gear (keeping the engine off), I can pull in the clutch lever and roll it, both forward and backward, the bike rolls a couple inches, gets stuck almost, and pops. Kind of like the piston is going up and down with the clutch pulled in.
-When turning the bike on and in neutral it sounds fine, until you release the clutch lever and then a consistent and very loud rattle sound starts somewhere in the lower section on the right side of the bike.
-I can shift it into first and all the way up just fine, but still get the rattles until I am over 3rd gear (and maybe it just gets too windy to hear it? Not sure)
-At speed and mostly when I am slowing down to a stop, pulling clutch you can hear the popping/clicking noise until stopped, similar to the first point.
I am for sure going to take it in, unless it's something I can easily fix. But I really need some help!
Thanks,
Taylor
Thanks,
Taylor
