gsferrari
Hi,
Pulled my hayabusa out of storage after 1 year and although it starts and runs fine - there's a mild enging surge at low speeds and it doesn't appear to be firing as rhythmically as I remember. The bike was started periodically and put into 1st gear on high-speed-idle for 5 minutes every sunday during it's time in storage.
Everything else is fine - I still hit decent speeds easily and there doesn't seem to be any drop in power.
The stealership recommended a fuel additive that would clean out the injectors etc.
Please advise on whether this is a recommended solution that I can try. If yes - what additive do I use that is easily available at the local gas-stations - how do I use the same.
Thanks people!!
Thanks people!!
