Stripped Upper Engine Mount Bolts
besjr69
Ok, I'll take all of the insults for being a bone head, but now I need some advise. I was installing a set of T-Rex frame sliders on my bike which requires no modification to the fairings. Anyway, this installation requires the removal of both fairings, and the engine mounts (one at a time). After loosely fitting everything (tight behind the radiator and fan) I started to torque everything down. In the process I over tightened the upper engine mount bolts. I did apply loctite after cursing myself for about an hour, but after a couple weeks of riding I note that one side is a little lose. According to the parts diagram (see OEM Frame Diagram items 9 - 12), it appears the bolt holes are actually bolts and nuts themselves. The part numbers are:
SKU: 41921-19F11
BOLT, CRANKCASE ADJUST
SKU: 41921-33E11
SKU: 41922-19F11
NUT, CRANK CASE ADJUST
SKU: 41922-33E10
...for both the right and left side. Has anyone ever stripped one of these bolts and had to replace these bolt sockets? I'd rather do the repair myself, but if I have to take it to a dealer I will. It seems like it may be an easy fix.
Bobby
Mr Bogus
Trouble Makers Inc.
never mind... I gotta see what this backer nut is... someone probably already has the fix...
hmm looks large enough for a thread sert (or helicoil) fix.. probably cheaper to replace them (14$ each, thread repair kit is probably 30) PM GoldenChild, bet he has them..
Thread starter Similar threads Forum Replies Date
bird1300 Stripped threaded hole General Bike Related Topics 4
Vetteman761 Exhaust manifold bolt hole stripped Busa problems 3
Dr. Gonzo How I went from being annoyed at stripped screw to feeling like a genius yesterday... Random Thoughts 15
B 'Busa stripped down for powdercoating General Bike Related Topics 7
B Stripped the head of a bolt taking off the factory exhaust Busa problems 20
QWKENAF Stripped her down today... General Bike Related Topics 16
H Stripped threads Busa problems 4
skydivr So I stripped it (help) General Bike Related Topics 54
screamin kanji Need help in this decision process(stripped oil drain plug) General Bike Related Topics 21
nabusa Oil plug stripped Busa problems 4
III Stripped pinch bolt...looking for suggestions General Bike Related Topics 14
B Another stripped oil pan Busa problems 5
Nicholas chain adjuster bolt hole stripped.. Busa problems 24
C Stripped allen bolt Busa problems 15
jeremy_283 Could my oil pan be stripped/stripping? General Bike Related Topics 13
T 2000 model Starter Spline Stripped Busa problems 6
Payne Stripped threads on the oil drain plug General Bike Related Topics 17
L Stripped the Black Paint off Rotor Maintenance and Do-It-Yourself 11
N stripped oil drain plug Busa problems 26
W Stripped oil pan fixed! General Bike Related Topics 13
RedFalco Cowl Brace [stripped hole] advice. General Bike Related Topics 19
B some pics of the busa stripped General Bike Related Topics 9
Jayhawk Stripped drain plug Gen II Busa Information 11
jayy Right side Faring bolt is stripped General Bike Related Topics 14
kairles stripped M/C screw General Bike Related Topics 9
TIMMYDUCK My Busa has been stripped. 2008 Busa Bash 23
cobravenom39 Stripped Bolt in Engine General Bike Related Topics 7
P stripped oil plug Maintenance and Do-It-Yourself 8
flybybusa Headlight aduster broken/stripped? General Bike Related Topics 3
craigntx oldster uses shotgun on stripped lug nut Random Thoughts 21
0 Stripped Down!! General Bike Related Topics 14
1BadAssBusa 19 Weeks Stripped Down Appearance mods 24
D OIL DRAIN BOLT STRIPPED?? Busa problems 4
bigjohn141 Anyone ever stripped wheels before? Random Thoughts 5
S Stripped oil pan threads or bolt? Busa problems 18
Kevasa 6th gear stripped Busa problems 1
BIGSMOOTHH Wheee!!! i just stripped my oil plug Maintenance and Do-It-Yourself 22
GSXTacy Allen bolt stripped General Bike Related Topics 23
M UGH Oil Pan Stripped... General Bike Related Topics 5
F Stripped Allen Bolt General Bike Related Topics 10
D Stripped wheels General Bike Related Topics 19
S Stripped the oil pan threads Busa problems 12
Ludicrous Speed How to prevent stuck/stripped fairing bolts Maintenance and Do-It-Yourself 7
R Help with stripped screw General Bike Related Topics 12
Dr Geekenstein Stripped Oil Drain Hole Maintenance and Do-It-Yourself 13
Dr Geekenstein Stripped Oil Drain Hole General Bike Related Topics 18
S GAH Stripped bolts at the tank front mount Maintenance and Do-It-Yourself 3
outjustout Stripped drain plug Busa problems 5
Z stripped hex bolt General Bike Related Topics 9
04 Limited Busa Upper tree steering stem brass nut torque setting??? Gen II Busa Information 8
Similar threads
Latest Bikes
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
  • My 2014 Hayabusa
    • Dljat2
    • Updated:
  • Hi Everyone
    Loved
    • BirolBora
    • Updated:
Forum statistics
Threads
174,193
Members
48,294
Latest member
mdg5155
