strange problem shifting into 2nd tonight, need help
hemi
was out ripping on the baby tonight and thought i seriously damaged something. Got on it hard in first up to about 10k, went to slam it into 2nd and slipped shifting or didn't shift hard enough and went to neutral. Hit the rev limiter for just a split second when i slipped it into neutral. Let her come back down to idle for a few seconds (still doing about 50-60mph), went to kick it into 2nd and all of a sudden the motor stalls. Saw the oil light on and thought wtf!! but then saw she wasn't running. Tried to start it a few times while moving and immediately stalled. Coasted to a stop at the side of the road, took about 2 tries to start and it idled horribly like it was gonna die immediately. Revved her up a bit and all came back to normal, rode completely fine after that. What the heck happened? Think i damaged anything? Never experienced this before and don't know what it was. Are the busa tranny's pretty bulletproof as far as missing gears/grinding gears etc
Shaft
keep riding till it drops.. thats all I can say.
hemi
funny, funny. U guys remember me too well. No worries then?? Took it out again tonight and was running and shifting 100% fine, just got a little worried bc this has never happened before.
hemi
any idea why it stalled out like that and had trouble starting back up though?
kromdom
wannabe HOON
my guess: engine got starved of oil (when you shifted into neutral) and shutdown (hence the oil light)...failsafe mechanism to prevent damage to the engine.
kml
Clutched or clutchless shift?
jeepinocala
I was looking into a shift drum that is Neutral all the way down so all shifting is up no more worries about 1st to 2nd just not sure how big of a job it will be.:whistle:
kromdom
wannabe HOON
was thinking about a slipper clutch...help me not get into a high side
jeepinocala
Cant remember where but I did see an add for a all up shift drum I am searching for it to find out what all is needed.
aussiekeeper
When you hit the rev limiter, it went very lean on the fuel. Then you dropped the throttle, more lean condition. That is why it died. Sometimes it will take a little time to recover from a lean condition. The combustion chambers get very hot. If you miss a shift from 1 to 2, never try to shift it into 2nd while rolling from neutral, slow down to 15-20 mph, then shift into 2nd, then to first gear. These transmissions are good, but not bulletproof........
kromdom
wannabe HOON
aussie,
your point also came to mind but was not comfortable splaining it :)
myfirstbusa
I used to miss 2nd 20 times a day when I first got my Busa. Of course it was my first bike and I just wasn't used to it. But I kill my bike everytime I ride and I've never had transmission issues. I have 12k HARD HARD miles on mine and she's tip top... I think. :whistle:
crawler
Aussie is right on the neutral to second not being the best thing on the tranny. Keep in mind the tranny wants to go from first to second. Not neutral to second. Always try to slow down, shift to first, then shift to second.
