STL File for Oil Pump Priming
jtwrace
Before I go down the rabbit hole and draw one up to print, does anyone have a file they're willing to share for a tool that goes to the oil pump gear so you can use a drill on it to prime the oil pump? I know that using the starter is possible I'd like to be able to really build pressure for a bit of time to check the whole system (lines and cooler).
I take a piece of fuel line that slips over the oil pump shaft, put a piece of round stock in the other end of the hose and drive it with my cordless drill.
