Richy1340
Hi All I'm new to the group, my name is Richy and I ride a 2012 Gen 2 Hayabusa.
I have a starting related issue. When I hit the starter button, everything sounds fine and the bike almost wants to start, when it does eventually start after 2nd or 3rd try, it cuts out unless I give it a slight rev then it idles and rides normally.
My bike was boosted and recently took it back to start as it did not make economical sense as I use the bike daily.
I am starting to think the issue could be fuel pump related as I recently replaced the little grommet for the fuel pressure regulator on the fuel pump assembly as it was torn which caused spluttering until I ease off the throttle and bike would slowly ease up. I have purchased a new grommet and replaced it which sorted out that issue.
I also purchased a new fuel pump but have not fitted as yet as the current stock pump "seems to be working fine" or should I just go ahead and replace it and test it?
Appreciate any feedback
