SSGT_B
I wanted to Crete on singular post for discussion. As many of you have read in a few other of my posts, I have spongy brakes. To date I have:
. rebuilt calipers
. Arashi rotors
. New EBC FA188HH pads
The bike had stainless coated lines on it when I got it. I have gone through about 32 OZ of fluid so far trying to get what feels like air to me out of the system. Ive gravity bled, vaccume bled, pump and hold bled, open then pull lever till stop and close bled. Ive since removed the system as a whole and put it on the bench to do the work, mostly as it hurts to bend over and do this and to not make messes. Ive bench bled the master, then bled the banjos starting at master, then caliper, then nipple. Ive used a sander to vibrate the calipers in hopes of moving trapped air up the system. Ive taped them to my 80 gal compressor and let it run for same reason. Ive left the lever tied back to the bar for days. So here are my thoughts.....
Being as how fluid CANNOT be compressed could I have either:
. Air still in system
. The old lines were junk and need better ones ( not sure of manufacture )
. Fluid internally bypassing in master allowing handle to still be pulled past point of stop?
. rebuilt calipers
. Arashi rotors
