Right Turn Signal Issue
Cireous
My 2000 Busa's right turn signal stays illuminated when I turn the ignition on. My left signal works fine. The right one comes and stays on. I have replaced the turn signal switch. I replaced the start switch. I notice when the ignition is on and I unplug the start switch, it goes out. What could be the problem?
captain
Dis in my way!
You change the bulb and check ground?
Cireous
Fixed. Thanks guys. Because I have the 2006 harness, my problem was my start switch. That had to be 2006 also. So I switched both handlebar switches to 2006 and everything works fine
