Replaced Front Bearings
dyllinger
Hello everyone and I hope everyone is keeping the shiney side up. I changed my front bearings and when I put them back together I noticed that the guide that is between the two bearings was in there extremely tight. I know it was not tight when I took them off but I was kind of worried. I did do about 70 miles on them after I changed them and there was a squeak when I got back home. I know that I lubed everything but would the tight fitment of the new bearings cause any issues or damage the wheel or should I even worry about them anymore. Any advice is welcome. Thank you.
When you put everything back together did you tighten to the correct torque specs? Front disc bolts 16.5 ft lbs. Front axle 72.5 ft lbs. Pinch bolts 16.5 Ft Lbs.
