I'm replacing my front and rear bearings, which seems like a straight forward job. For the front wheel, I put the left one in first and seated it to the lip, then I put the hub bearing spacer in and put the other bearing in.
I don't know if I did it wrong because the bearing spacer was tight against the bearings, but I could have sworn when I took the wheel off I could slightly move the spacer.
So, am I crazy? Is the spacer supposed to be tight against the bearings or should it be loose?
