c10
So I received my relocate bracket in the mail . I wanted to note I make my living finding grounds/shorts/lose connections in low voltage wiring.
Anything you can do to prevent issues is KEY to less worries/being stranded with a blown main fuse . Or worse a FIRE !
The threads on bolts over time/vibration are dull knives that cut/wear the outer jacket of your wiring . Tying your tie straps to tightly to the frame
can cause ground faults . A Tie strap to a tie strap is a good way to prevent this . In other words put a strap on the frame directly . Then push a 2nd tie strap through that strap , and use the 2nd strap to hold you wiring .
Here are some pictures for you viewing pleasure .
This is bad
See how the rectifier pwr wires touch ?
Solution simply reverse the bolts like so
In this picture I used a piece of rubber ( from under your battery on the tray ) to strap to the frame so that the Rectifier power wires will never rub to ground .
On a separate note it seems the later Gen II's have heiver gauge wiring/different rectifier . Looks quiet beefy compared to some I have seen .
This is bad
