rear sprocket/tire question
gauloises
hi, i want to ask if a 43T rear sprocket will go well with a 200-55-17 rear tire? enough clearance?
gen1, k7 busa....
thanks guys...
dadofthree
Seasoned Beef
Clearance should not be an issue, the 200 tire comes close to the chain but should clear.
Rollin20z
As of now I'm running a 200/55 Super Corsa on my Gen 2 with a 18/45 set-up and going by gearing commander it's pretty close as same gearing wise as stock with the 190/50 18/43 with maybe like a 1/2 tooth more. So I guess upping to the 200/55 is like dropping 2 teeth on rear or pretty close to that.
And as for clearance as have no problems whatsoever but I also run the HotBodies undertail on mine so I wouldn't be sure if you have stock, but honestly I still wouldn't see a problem. Now a hugger is a different story, had one on with the 190/50 but no way it'll even think about mounting with the 200/55.
Rollin20z
So in the end your tire size will offset the sprocket by roughly a little over 2 teeth, so it'll be like you running a 41+ sprocket instead of the 40 stock. In reality you gain a touch more low end(may not even notice) and lose approx 4mph top end theoretically.
@ 10,500 rpm GC is saying:
Stock tire w/larger sprocket 170.9
Stock tire stock sprocket 183.7
200/55 tire w/16/43 sprocket 179.1
200/55 w/stock sprocket 192.5
Of course speculative speeds.
Rollin20z
thanks, i don't wanna lose the acceleration when i get to 200-55-17
With the 200/55 tire and going up to a 43 sprocket you will not lose acceleration, but gain a very minimal amount. Going to a 43 sprocket but sticking with stock 190/50 tire will put a boost in your acceleration but you'll sacrifice some top end speed. All depends on what your looking for.
Or if your just wanting the 200 width but more acceleration then just go with the 43 and do a 200/50 and not the 55 and you won't gain as much height on the tire. That's another 10mm in height which adds another 2.5" of circumference to the tire.
gauloises
i'm now on 190-55-17 rears, 17F 40R sprockets, just bought a 200-55-17 to try out, was thinking if i change to 43R with the front remaining 17T, i will get back some acceleration
flippnswitchez
I ran a 16T 45T on my gen 1 with a 200 and clearance was fine. I currently run a 190 now and I am thinking of going down to a 43T. Acceleration is friggin AWESOME and soooooooo much fun. With the mods I have added I have to come down, also I don't like running the bike at such high RPMS all the time.
How does that big ballon tire handle hot in the corners:poke:
pashnit
Site Sponsor
Btw, here's the shot of the bone stock rear end with factory 190 tire.
Noticeably smaller.
Here's the 200.
Noticeably wider.
And the 200 on the Gen-I. Now go ride! :thumbsup:
gauloises
erm guys, my questions is, stock chain with 17T front and 42T rear- bringing the rear tire closer to the front of the bike. Then, by using a 200-55-17 rear tire, it will be closer to the front(higher sidewalls). So my question is that, will the tire actually have enough clearance so as not to touch the swingarm( if you look at the bike with the direction facing this way <== , it’s the wheel at the 9 o’clock position. Want to ask if will the tires will have enough clearance? Not asking if it will rub the chain(horizontally)
Thanks guys
Thread starter Similar threads Forum Replies Date
J Rear Sprocket question Gen II Busa Information 20
B Gen 1 Stock Rear Sprocket Brand Questions Engine and Performance mods 7
shade Rear sprocket bolts Gen II Busa Information 8
Skywalker Vortex Rear Sprocket Question General Bike Related Topics 28
B Rear sprocket tooth count. Gen II Busa Information 45
Busa Burt Downsizing rear sprocket Gen II Busa Information 30
6 inch over Front or rear sprocket Busa Mods 6
Busa1166 new rear sprocket General Bike Related Topics 17
Bob Morin 16 Front 46 Rear Sprocket 2012 Hayabusa New Owners Forum 10
Bob Morin 16 Front 46 Rear Sprocket Anyone??? Pay It Forward - Members helping Members 1
TallTom Another cautionary tale on rear sprocket bolts General Bike Related Topics 3
O couple quesions re rear sprocket and coffman shorty exhaust General Bike Related Topics 3
Lunchy Rear Sprocket Question Busa Mods 2
darkbusa Front/rear sprocket replace Engine and Performance mods 44
H rear sprocket General Bike Related Topics 12
mikey28804 43t rear sprocket question Maintenance and Do-It-Yourself 13
novabusa aluminum rear sprocket question General Bike Related Topics 19
SS14PSI Who sells a 52t steel rear sprocket? General Bike Related Topics 6
MoNoXiDe Clicking by the rear sprocket Busa problems 60
piratediverjefff Purty New Chain & Rear Sprocket Gen II Busa Information 18
lankeeyankee Switched from the 46T rear sprocket back to the 43T Gen II Busa Information 33
hayabusapower Changing Rear Sprocket need some help. General Bike Related Topics 29
A rear sprocket Gen II Busa Information 9
DragginBusa 45 vs 46 Tooth Rear Sprocket Gen II Busa Information 62
P Smaller rear sprocket? General Bike Related Topics 8
binx Rear sprocket movement General Bike Related Topics 13
bowhunter84 gen2 rear sprocket? General Bike Related Topics 8
billyerds01 Chrome Rear Sprocket General Bike Related Topics 0
C +5 rear sprocket - top speed ? General Bike Related Topics 17
IRDEATH 2008 rear sprocket question Gen II Busa Information 7
Chasx Rear Sprocket Play Busa problems 8
StwBusa Rear Sprocket Busa Mods 2
G rear sprocket question? General Bike Related Topics 3
G rear sprocket wont bolt up help!!!! Busa problems 1
John V Swapping to a GSXR 1000 rear wheel some Sprocket/Rotor questions Busa Mods 2
P Quick answer on rear sprocket please General Bike Related Topics 3
S Rear sprocket General Bike Related Topics 3
czeebBusa Rear sprocket play General Bike Related Topics 10
yamanista rear sprocket New Owners Forum 3
jnaquin72 Rear Sprocket Gen II Busa Information 27
Speed King Sprocket teeth, front and rear? Gen II Busa Information 3
johnny1980 rear wheel sprocket question General Bike Related Topics 7
bpjones Changing Rear Sprocket General Bike Related Topics 6
B Rear sprocket General Bike Related Topics 13
delock Rear Sprocket and Drag Chain Gen II Busa Information 9
A Sprocket and rear axle ?s General Bike Related Topics 3
highestgrade chain on rear sprocket General Bike Related Topics 5
Evil_keeps_me_young New steel rear sprocket... Gen II Busa Information 25
Stealth08 Calling all 44 and 45 tooth rear sprocket users Gen II Busa Information 39
mike1180 Vortex Aluminum Rear Sprocket after 8,000 kms Random Thoughts 9
Similar threads
Latest Bikes
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
Forum statistics
Threads
174,423
Members
48,410
Latest member
Will.Wells
