Rattling (or is it knocking) sound between 3 to 4k RPM
You should cruise at a minimum of 4500 rpm and in 6th gear, that's about 85 mph.
Downshift that bad boy!!! Make that engine SING, brother!
--Wag--
It actually rattles all the way to 8k and it does it in all gears. 3-4k at 6th is where it does loudest. So, I just seeking help to understand this abnormality so that I can correct it. ???
You should have said this sooner...try a different brand of fuel...at least two tanks and then report back.
During the break in, you really should not be lugging it. The most important thing is to get the rings to seat. From what I am hearing, I would take it back to the dealer. My truck sounds that when I put a hard load on it. My truck also has around 200,000 miles on it.
