I have the Corsa Corta RCS and love it.Brembo RCS17 Master Cylinder , and if you want even more fine adjustment , try the Brembo Corsa Corta RCS17 , both perfect for Brembo Stylema calipers on the Gen 3 .
Used one of these?. The LE has it and provided more feel over the 19 & Corta.Brembo RCS17 Master Cylinder , and if you want even more fine adjustment , try the Brembo Corsa Corta RCS17 , both perfect for Brembo Stylema calipers on the Gen 3 .
Yes , the billet unit , but you run the actual recommended top shelf ultimate race unit dont you bro , on your LE , a beautiful expensive piece . I actually used to run a brake setup 19 x 18 billet , paired up to 2 Brembo P4 billet 40mm spacing calipers , on the old oil burner GSXR s . I bought the original release around '94 I think ish .Used one of these?. The LE has it and provided more feel over the 19 & Corta.
Brembo Racing CNC Billet Radial Brake Master Cylinder 19x18
Yep, figured I was already down the rabbit hole then why not. Have a set of GP4-RR calipers in the closet.Yes , the billet unit , but you run the actual recommended top shelf ultimate race unit dont you bro , on your LE , a beautiful expensive piece . I actually used to run a brake setup 19 x 18 billet , paired up to 2 Brembo P4 billet 40mm spacing calipers , on the old oil burner GSXR s . I bought the original release around '94 I think ish .
Monobloc loveliness , the ultimate 108 mm nickle Brembo , love it bro . Now you can't mention billet clutch and not fill me in ... I will wait patiently for more info on that bro .Yep, figured I was already down the rabbit hole then why not. Have a set of GP4-RR calipers in the closet.
Have the Billet clutch too.
Hmm. Ordered on Sunday and arrived today! Smokin deal too.Patiently waiting! Parts ordered, just gotta be patient.
Anyone remember which EBC HH pads fit the 2022? I’m getting a couple different options.I looked into getting a Brembo MC, But did not think is was worth it. I have fitted Brembo Calipers with EBC HH pads and Hel front lines. For the road the stopping power is very good even when riding 2 up. My bike is a non ABS model.
When i first fitted the Brembo calipers i was not happy with them, So i swapped out the Brembo pads for EBC and wow so much better.
Try changing the pads first to EBC HH from the OEM pads.
Going by EBCBRAKES.Com the ones for the 2021-22 Hayabusa are FA419HH. I think the G3 has the same Brembo calipers as the G2.Anyone remember which EBC HH pads fit the 2022? I’m getting a couple different options.
The Brembo M4 calipers are Gen 2 , the latest Brembo Stylema calipers are Gen 3 . Not up to speed on pads for either though .Going by EBCBRAKES.Com the ones for the 2021-22 Hayabusa are FA419HH. I think the G3 has the same Brembo calipers as the G2.
