There are several ways you can do it. If you use an existing circuit, I would use the headlight circuit since it is designed for a heavy load. Either way your detector needs its own fuse link so you would be better off giving it a circuit of its own and you do not have to worry about overloading an existing circuit.
there is a "factory" hook up for an accessory behind the guage cluster. You should just use that for your source as its already "fused" and designed for such things.
