Q16 or MR12 on 16:1 engine compression
That was a joke. I say that because I knew you were using a stand alone ecu that can take care of adding fuel for nitrous on top of fueling for boost as well. There’s no reason to run a wet kit.
pretty much the only guys that use wet kits are carb guys. And guys that don’t want to build a proper fuel system.
Hi. Things change so fast these days who knows what is best! I am going down to DME to talk about turbos. They are doing a single throttle body now.
I can say this. Q16 to ignite e85 I saw a 5-6hp gain on a large displacement higher compression NA engine.
On another similar configured bike I saw a 12-13hp gain from ignite e85 to Vp X98.
Wow
What about x98 vs C45?
BTW..Do you faced atomization issue with the ethanol? Still make power at very top end ( over rev ) on the dyno?
