I was reading another post where a member was having similar problems but not exactly the same as mine. I didn't want to thread jack as it can get confusing trying to diagnose too many different bikes in one thread.
I've got an 06 LE that I put a 4-1 Muzzy on this winter. I am running a PCIII, downloaded the map from the website for the Muzzy system when I installed the exhaust. I just turned 6000 miles on it today. I only run shell or amoco 93 octane in the bike. Running stock air filter right now as well. I don't have a TRE or any other engine mods at this time. I will also add I ran the PCIII with my yoshi carbon fiber slip ons and had zero problems with the bike.
The problem. Bike runs great under hard acceleration, no problems at all. When I take it easy at town speeds it I normally run around 40mph in 2nd gear, puts RPM right at 4k. On a constant speed like that in the 4-5K RPM range the bike is not smooth, engine wants to buck a little. When I clutch it and rev it, motor sounds and feels like its loading up.
Exhaust is dry black soot, washes off easily with water. Also it seems since the exhaust change my fuel mileage has also tanked. I rode less than 50 mile today. Fuel tank was full when I started, gauge is showing 1/2 now.
I've also burned a couple tanks of gas in it this spring so gas should be fresh.
I was thinking about starting off with new air filter and changing plugs. Any other thoughts? Should I try a different approach first, if so what?
Any thoughts or suggestions would be appreciated.
