I have a 1999 busa motor in my sandrail and I have a problem which is getting worse. The problem seems to only occur in gears 3rd and up when I am on the throttle, as soon as I let off the throttle it completely disappears. It almost feels like a studdering if that makes sense. It has gotten to the point where it doesn't matter if I am accelerating up a dune or just on the throttle maintaining a constant speed on flat ground it does it. It also seems to be happening in the 4-6k rpm range and almost goes away above that. I thought it was the clutch slipping so I installed APE's HD springs and the problem is still there. It started out as an intermittent thing but is now pretty much constant.
Any ideas? Could something in the tranny be bent which would affect gears 3 and up? I am kind of at a loss here and any input is appreciated.
Thanks,
Derek
Thanks,
Derek
