Non abs wheel to abs
Berlin Germany
Can a non abs rims be turned into abs ? I can't find some abs rims for my extra set of tires.
If abs is disabled does that affect the ECU fuel or ignition in any way?
get the abs sensor wheel and drill ´n screw it into the recess on the rim hub
the gen2 rims have the same meassurements - no matter if abs or non abs.
the abs system is a 100% self-contained control system and does not have any influence on the ecu - the abs is, so to speak, a set-up regulating body solely for the brakes.
and without (switched off) the abs the brakes MUST! work as usual !
