Denzilmedland
Morning all,
i have a 14 plate Gen 2 with ABS, i really need your help on a problem, upon heavy braking with the rear brake it will lock the back wheel and actually stall the engine, the ABS light then stays on until i turn off the ignition, then all will be restored.. When i start the bike and pull off the ABS light goes out as normal, it just locks the back wheel up and makes no attempt to work, there is no pulsing from the brake or anything. I have noticed that the ABS ring is rusty but the sensor wire all looks good and if there was a fault with the wire then the light would be on all of the time.
I am beside myself with knowing what to do, has anyone had any experience of this on their bike ?
I thought i would change the ABS ring for a new one for starters then the cable etc.
thanks.
thanks.
