I have a 2000 busa thats been giving me problems for about a week.At low rpm it boggs out and sometimes even dies "which is on the regular now" I changed the fuel pump thinking that was the problem but its gotten worse.It will run for about ten mins at a time then die and wont start up immediately,it takes about 15mins then itll run another ten mins an die again.Ive checked all handlebar connections,sidestand,battery"All the usual things to check and they all appear fine.Im stumped...any help would be greatly appriciated.thanks
and its prob. trying to hint you to buy another busa
Ive replaced the pump,filter,injectors,checked all electrical connections,done everything i know to do and Im outta ideas.If you get yours figured out please lemme know what you found.Thanks..
