Masterlink question
showtime
Now from searching and reading, there's a pretty lop-sided consensus to stay away from clips. I understand
. However, I have purchased an EK screw type masterlink to go on my brand new EK ZVX2. The chain also came with a riveted link. I don't have the tool nor do I plan on buying it or taking it to the dealer for 2 minutes of actual work that's gonna cost me a full hour. I don't race, I rarely wheelie or do anyhing that's going to over work the chain. Should I just suck it up and have it riveted or is the screw type link perfectly fine to go with?
Rivet. You would be glad to pay an hour of labor if your chain broke and ruined your engine case or caused you crash. Think about it. What is more important than the part of your bike that connects the engine to the drive wheel.
I prefer a rivet link myself and would not use a clip type on my bike.
I honestly think this is a pretty good product and do not see anything wrong with it. From the pictures I have seen, it pretty much is just a different way to rivet it. I've got the tool, so I don't have a need to use it.... but I would consider it if I was in your situation.
I already have the tool so I use the rivet type, but if this is the screw type you have I would use it.
Do they rent chain riveters. If not, I'm thinking of buying one and charging a small fee to rent it for a job.
Like a $150 deposit, and when it's returned I'll refund you $120, including shipping to you.
What do you guys think??
I can just sell you mine for $40 and you pay postage.. You are then required to sell it to the next .oRg member for $40 plus postage...
Sort of like the shim bank
Sounds like I might be buying a riveter... Like I said, it's a ZVX2 chain (pretty strong) and I don't show out on my bike a lot. But safety is paramount...
Do the rivet. Clip on links are not recommended for the 530 chain but comes with them. Just look at your factory chains. I would only use a clip on link as a means to get to a safe place where I can install a rivet link.
Where are you in GA. Get on one of the GA boards (GSB or BSB) and I'm sure you will be able to find some one close by that will loan you there tool. The only bad thing about loaning out the tool is that it's better to grind down the pin on removal and some people may be a little to lazy to do so, and pushing it out with the tool may stress the pin a little too much...
So where are you in GA?
I'm in the great metropolis of Brunswick. 1 hr north of Jacksonville and 1 hr south of Savannah on the coast.
...I don't have the tool nor do I plan on buying it or taking it to the dealer for 2 minutes of actual work that's gonna cost me a full hour....
I just had my ZVX2 chain installed by a local shop for $65. I can tell you it did not take two minutes. Drive on maintenance stand and drive off when finish was about 40 minutes.
Cut rivet of old chain
Thread new chain on sprockets
Cut off about 8 links from new chain
Rivet on the new chain
If I had the tools I would of done it myself but I didn't.
Rivet is the best and safest. I used to think either way but I knew the rivet was stronger. I've gone many years (6) with clips until finally the clip busted on the freeway and busted the sprocket cover and could have locked the rear wheel up and could have had an accident but I was lucky. So, suck it up and buy the chain tool. $100 is cheaper than a hospital bill and the bike/parts repair bills. If bikes are going to be in your life for many years, buy the tool.
I paid $85 for the rivet tool.
Done five chains for myself and friends since then.
Yup. More than paid for itself by now.
--Wag--
The best "endless chain" tool is $60. It does all the link extraction and reassembly except one thing....that is creating a mushroom surface on the end of the "master link" (I call it a masterlink because it is the final assembled link to close up the chain...not because it has a clip like a traditional master link).
The way to create the mushroom is by purchasing an air hammer (Harbor Freight, $9.95)and, using the pointed bit, mash the ends of the link shafts over the outside linkplate surface...at least to the level equal to the adjacent factory links (you are spreading metal)remember to grease the links 2 shafts and place the little O rings first. The other side of your "masterlink" must be held/contained securely in place during the air hammering. Once you do it the first time, you will be that much more independent from others, because YOU will have the tools and skill. Raydog
