lookin for some help
Tell us what you got. What times are you running now? What times are you looking to run? What's your budget?
16/42 sprocket change... thats what lots a guys on the board have done!! Getting it done next week... i'll post in a review onceits done
im lookin to get the most out of the bike for drag racing
without havin to go into the motor right now, i might put cams in
im 6'1 220lbs
im running 709 720 715 and 730s right now at about 113mph to 100
but id like to be in the 6ss
the 16 42 works for yall
is there any body that races the 1/8 mile
We got a 1/8 mile track close. 16/42, Lowering links, strap, Pipe, Shinko are some things to consider. Ludicrous Speed has run 6.50's stock bike, 16/42, Shinko and airshifter, stock exhaust. He's a big guy, prolly weighs 240 or so. I'm running 6.60's, 112mph, 1.70's 60 ft, 6" over arm, 2nd hole 'bones, strapped, yosh pipe, 16/40, shifter and Shinko. I weigh about 280 w/gear.
<!--EDIT|Mr Brown
Reason for Edit: None given...|1119365776 -->
cool ive got it slammed now< this ive done after the post>
and got a strap on the front
yoshi slip-ons
and now i guess go to the 16 42
since ive slammed it ive been gettin better reaction times
whent from cuttin like #### on the line <.295>
now i slammed it i pulled off a .002 only one time but always .020s and .030s and .0teens
but still runinng in the low 7s <7.14>
<!--EDIT|redjamesbusa
Reason for Edit: None given...|1119533547 -->
All of the mods in the world is not going to play a part in your reaction times. Thats all you and how you react to the lights.
I run consistant 6.1's to 6.3's in the 1/8th at 114 -115 mph. I am running a 16/43 gear and it works great but, I also run the 1/4 mile. I have not done anything to my motor as of yet. I would suggest trying getting to a wide open throttle as quickly as possible. What are your 60' and 330' times? That is what is going to tell us how you are doing as far as leaving the line. Hope this helps out!
Ignore your r/t and e/t's next time, and focus on your 60'. Once you get them low, (1.5's,1.6's) concentrate on your 330' times. Once you're consistent with your 60 and 330 times, start working on your r/t, and you will see your e/t drop. It don't matter how well you react to the light if you can't ride down the track......
ok here is some of my 60 and 330 times
2.196,5.296
1.974,5.296
2.165,5.263
1.930,4.983
1.869,4.838
and i still have not done the 16/42
OK...Bottom line is your 60's suck and bad...Concentrate on the clock and only the clock...I don't care how many bike you race it's the clock that's your opposition...Get your confidence up and address your 60' that's where your time is...
2.196,5.296
1.974,5.296
2.165,5.263
1.930,4.983
1.869,4.838
Like Stunnah said, your 60' times need work. Try leaving at a higher rpm and slipping the clutch. If you get your 60' lower, your et will drop all by itself. Practice is the key. I don't know if there are some deserted areas around where you live, (country roads, industrial parks at night, etc.) but try and find a good stretch of road and launch, run out first, stop and repeat as many times as you can. Practice slipping your clutch and getting the throttle wfo as fast as you can. it'll come together for ya, just keepm after it.
2.196,5.296
1.974,5.296
2.165,5.263
1.930,4.983
1.869,4.838
+1
