I have found a way to add yet another spike to Misty.
However I need a little advise here.
I took an aluminum spiked footpeg, Cut it down to size then hollowed out inside to fit over this polished brake pedal.
I was thinking of filling the hollowed out area of the spike with JB weld and then place it over the pedal until it dried. Will this work.
I got a suggestion of drilling a hole and using a pin but the hole is a little bigger than the pedal so I think it would fit loose and rattle.
Anyone have any ideas other than JB Weld if you think it will not work.
