LOL, this is crazy! I want my ZX14 back!!!
wee
I kept bothLOL, this is crazy! I want my ZX14 back!!!
wee
I have had both sides off 3 times so far, although I never found this hidden 10 mm. bolt. dont forget the push pins in the nose wheel well.If you have had the right off, the left is the same without the hidden 10mm bolt.
When all bolts and push clips are out pull out from the bottom carefully then lift up. The last rubber grommeted clip is vertical. Don't pull straight out.
IMO those push pins located there, are the most difficult.I have had both sides off 3 times so far, although I never found this hidden 10 mm. bolt. dont forget the push pins in the nose wheel well.If you have had the right off, the left is the same without the hidden 10mm bolt.
Slide 6 and 7 https://www.hayabusa.org/08-busa/2008BusaOilChange.ppsI have had both sides off 3 times so far, although I never found this hidden 10 mm. bolt. dont forget the push pins in the nose wheel well.If you have had the right off, the left is the same without the hidden 10mm bolt.
Its also much easier to "break" the ridiculous unecessary fasteners that suzi shouldn't have put on anyway, and make the whole damn process easier like it shoulda been. I have no patience for this form over function BS...something CAN be designed to look good and ALSO be easy to work on for the ownerits much easier after installing the fairings a couple of times.
wee
+1Its also much easier to "break" the ridiculous unecessary fasteners that suzi shouldn't have put on anyway, and make the whole damn process easier like it shoulda been. I have no patience for this form over function BS...something CAN be designed to look good and ALSO be easy to work on for the ownerits much easier after installing the fairings a couple of times.
weeNo excuse in my book
