Does anyone know if I can install the right side inner fairing that the turn signal mounts to. Do I have to take the right and left side panels and front nose off to get at it. Just hopeing for a shortcut.lease:
Thats what I thought and you only need to take the nose if if you want to change the lens, but you can still get at the bulbs from the covers between the fairings and the tank.
there are push pins under the nose you push them up just slightly then you can pull them down and remove...take off the black plastic piece out from under the nose then you can reach up under the front end and nose to where the turn signals are and also to the screws if you need to ever aim your headlight etc...
You should be able to just pull the nose off and be able to get them off. There are 4 screws holding them on, undo those 4 and take your turn signal lens out and it will come out.
