PADEROLIS
Okay here goes... For a while I have complained about bad gas mileage on my 08, especially compared to other Busas. I've always said my 07 got much better gas mileage. My 08 has been running rich due to a leaking vacuum line that I recently found, I corrected it. I pulled all four spark plugs and cleaned the black soot that had developed on them, I also pulled the O2 sensor and cleaned it, I used a wire brush and brake cleaner. A mechanic friend of mine suggested I replace the O2 sensor because he said it may be damaged from the bike running rich so long, I don't have a check engine light on.
Also when Frank at PowerHouse flashed my ECU, according to my label, he disabled the O2 sensor. But if I unplug it, my check engine light will come on. So what does it mean that it's disabled? Does it still have an effect on my fuel/air system? Does replacing it make sense, or will I be wasting money since it's been disabled in the ECU flash?
