Intake air temperature
some plenums don't have a bung, my first didn't
Should be on the cold side not the hot side
DOWNSTREAM of core
FWIW if you are using the OEM sensor closed element it response so slow that u matters little,
Shameless plug
Scott D is adding a hot side so I can log both
DOWNSTREAM of core
Shameless plug
I don't mind adding one, in the process of finding a bung. Need to know the thread size. Temp difference between outside of plenum and inside should be enough for trouble of install right? And will have it for a rife when I go standalone. The advantage of seeing pressure from before and after cooler? Thanks
