Hi ,
I have a turbo Hayabusa, Gen 1, compression 8,5:1, (spacer 2 mm).
Where can I find the ignition map that such an application (boost around 14-16 PSI)?
If no one has a ignition map, how many degrees should move the ignition (approximately)
I've had problems with detonation, so now I have a fear
Thank you very much
Thank you very much
